Well I had tried to get my fuel filter off once before a few years back...I could get the banjo bolt loosened but the other side I just couldn't get undone. I even took it to the dealership and they said they couldn't get it off. Tonight I decided I was going to try again. I doused both the banjo bolt and other side in liquid wrench and wd-40 the night before. When I finally got underneath the car tonight I tried the banjo bolt first, it came right out. The other side is where I had problems. The dealership must of rounded the nut off on the out side. That is probably why they couldn't get it off. I used a line wrench and tried to get the damn thing off but it would just slip around. After about an hour of fucking around with different sized wrenches I ended up bringing out the vice grips. At this point I was out of options. Somehow I got those fuckers up where the filter is and clamped down on the rounded nut. I held the fuel filter in place with a 3/4" wrench. Finally it came loose. After I got it loose I could use a 14mm wrench to turn it, it was just too tight before.
How I got it off:
My Mangled FUEL FILTER:
Good Riddance...
How I got it off:
Good Riddance...
