cut harness need help
dinhnerz
52
Cali
I got a 1jz wiring harness that seem to be cut at the body plugs and fusebox. Its from I believe a jzz30. Its what I ordered but who knows. I know forsure its not from a supra.
Anyways its going into my sc300. My question is, will I be able to use the body plugs off the sc300 2jz motor and fusebox plugs and wire it up the 1jz wiring harness and have it work correctly? Has anyone does this?
I realize I can probably buy a wiring harness and ecu from a 1jzgte supra and swap body plugs but thats alot work if I'm going to do that might as well fix the wiring harness I have. I can't find any soarer wiring harness within the last 4 months I've been searching.
aphxero
787
Seattle, WA
Yeah of course you can merge them. Just pin it all out, trash what you dont need, then use what you do. Wrap it all up and go go go!
