I am planning on going ffi this winter and will be putting the battery in the spare tire spot so im selling the custom fiberglass box i built that fits perfectly over the spare tire holding bracket so you can go back to stock easily without modification.
the only thing you must modify is to cut a hole in the hatch carpet for the sub and wiring holes. I will include my burgundy carpet if you need that color, or i have an extra grey one if you need that color. if you need blue, I can help you find one or take some cash off the price of the setup.
the setup consists of-
fiberglass and mdf sub box with cutout for JL 10"w7 sub. the opening is slightly smaller than most 10" subs, but could possibly cut larger to fit any 10" sub. the internal box volume is approximately 1.1 cu ft.
rarely used JL audio 10" 3 ohm W7 sub comes with original recipt, manual, and complete original box and outer carton.
Alpine MRD-M1001 mono block class D amp.
I have the original box and manual for this as well.
it puts out 1000w rms at two ohms so im guessing its somewhere around 750 at 3 ohms which is more than enough for this sub.
I rarely turn the volume up, but just before the sub warranty was up I took it to the shop i bought it from and had them check it out just in case. They cranked it way louder than i thought it would ever go and I was kinda scared, yet amazed how loud it was. I have never personally cranked it that high for fear of blowing it, but they said it could still be turned up a little more than that without any fear of blowing. they said it sounded good and was nothing wrong with the sub.
note- there is no wiring or distribution blocks included, just-
box, sub, amp, amp mounting board, and carpet
you can see the completely documented box building here-
http://smg.photobucket.com/albums/v322/audioman81/mk3 sub box/
$750 obo plus shipping
