CT26 to T3 or T4 Adapter
empera
Authorized Vendor
Philly.
i got a custom ct26 to t4 adapter...also have the downpipe that i used with is, its a 3" v-band
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
i have an original Maxx Autoworks T4 adaptor. doesnt need anything welded. its already got a flange for a tial 38mm WG. its stainless steel and such.
i have a couple more pics if you need them.
bowsercake
828
Irvine, Ca
I have a stock manifold to T3 adapter for the GReddy TD06SH turbo kit for the 7M. I'm not using mine and it is brand new with a gasket. Shoot me a PM with your offer if you want to buy it.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
Redundant question: Redrilling turbo housing makes t4 housing usable on stock manifold right? pretty sure its yes just verifying.
Did you have to port the Bore in the housing at all? looks rounder then a regular T4 Bore thats more rectangle.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Crap i need to get one of these ct-t3 risers. I got a 57trim t3 sitting on a shelf i could use when my stock ct goes south.
dbsupra90
toonar
indiucky
yeah i see what you mean, but sp often port their turbine housings for flow. they are the ones that did the mod, i kept the pic for reference. if you ever saw the option for their bolt on turbo t4, this is what you got.
Apr 6, 2005
339
Alpharetta, GA
Anyone will say anything to make a sale. The adapter needs to angle upward for the turbo's compressor housing to clear the shock tower, else it will hit. Only a small (puny) size comp' housing will fit with that straight adapter
Cya said:
I e-mailed them and they said it would fit and do it well. I can't verify though.
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
yeah, thats why Maxx autoworks put a 90* elbow between the 2 flanges to raise the exhaust housing out of the way of the shock tower... which is why mine isnt an $80 cast iron sandwich adaptor... its actually Meant to work on the Supra.
