huntin5L,
If you just want the kit, what not try the link that was provided to you.
I bought a compressor wheel off of that seller on eBay.
http://cgi.ebay.com/ebaymotors/CT-2...33742QQitemZ8040374510QQrdZ1QQsspagenameZWDVW
As far as balancing them, you only have to rebalance a turbocharger's rotating assembly if you change it some how as in:
1) Changing a compressor wheel
2) Reassembling parts differently than the way they were assembled in relationship to one another. Parts not marked prior to disassembly.
If a component (compressor wheel or turbine shaft) has had wear, that would change the balance also, but at that point, you may need another compoent as it won't be any good any longer. So we won't make that a "3)"
EDIT:
Didn't know you responded, isnms. heheh
