ct26 installation
BryanDyer
654
Georgia
well how did you get it off with the pipe on the block? and now you're asking how to get it on the same way it came off? simply go in reverse on how you took it off lol
Trent
Quietly Browsing
Oct 30, 2007
78
Austin TX
That's exactly what you are supposed to do. Make sure the oil return is bolted to the turbo, slide the turbo onto the manifold studs, and line up the oil return with the block. If you have studs on the block its super easy, if not, bolts can be a bit more tricky.
