Ct12a swap
JASONA70
nomnomnom
Oct 27, 2006
743
socal
ok so i got the twins out, the turbo in the rear was the hardest to take out. i didnt remove the piping on the rear turbo, because it was almost impossible. now the turbos are out, but im having trouble putting the rear one back on any suggestions? pictures would be awesome.
935motorsports
San Diego, CA
If the job has to be done fast, I use the quick method.
Manifolds on first
Twin turbos with y pipe and oil drain tubes already attached
no intake pipes on either side
a flexible racheting 14 wrench takes care of the 3 nuts on either side of the turbo inlets
To get the rear intake pipe on (the hardest part), I stick the gasket on the intake pipe with some adhesive, and install the pipe with the bolts already in it.
I remove the abs line heat shield to gain more access. With the intake pipe in place, I start the bolts on the rear intake. It is a very awkward position, arm snaked all the way under the turbos and back up. However, it works for me and I can work the bolts on. Then a racheting 12mm wrench to tighten them. The rest is obvious from there.
Some people take off the turbos and leave the drain pipes on the engine. I'm sure it works fine, but I'm pretty sure my way goes faster and helps prevent possible oil leaks at the gasket.
I know it is hard to visualize, but hopefully that will help.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
i actually got the rear turbo on with the intake pipes! AMAZING! well im putting all the coolant lines back in and im having trouble finding copper washers, i drove to every single auto storei could find and no signof copper washers. can i reuse the old ones or do i need new ones? oh the washers are for the oil feed line. oh right will the turbos be starved of oil when i turn on the car? i noticed that most of the oil is drained. i just need some details, its my first time playing with turbooz
