CT12A Rebuild kit !
BigSupe
97
England
I'm sure the ct12 is from the 1g-gte which is a lot smaller than the ct12a in physical size, could the internals be similar
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Interesting, I never thought about that. You're probably right. I was always under the impression that CT12A was not an official turbocharger name, it was a CT12, but always referred to a CT12A to not confuse it with the CT12B.
With that being said, The internals might very well be similar between the 1G, and 1JZ turbos. Are the center sections the same size? I bet they are, I bet teh only differences are wheels and housings.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Easy on the brakes there newts.....
You can buy kits all day long for those turbos, but unless you have a shop that can balance a ceramic turbine system you're bummed.
...And unless you have a shop that knows how to balance small wheels accurately you're bummed.
Last, the only difference between CT12, 12a & 12b is the bearing width internally. Most of the other parts are identical.
GuNDeZZZ
Was dgilman360
Sep 28, 2006
619
Lakeland Florida
BAH i didnt even think about the balance
dammit im dumb
:aigo:
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
just go single and live happily ever after.....
ok and for joe's sake Upgraded twins will work too ;)
Jaguar
Permanent Ban
Apr 4, 2005
489
SoCal
www.supramania.com
How come nobody has numbers on these upgraded twins. :nono: I know The Doc is working on it, but he can't be the only set of twins that MDC has rebuilt. I want numbers and I want them now! :cry:
MDCmotorsports
Indy 500
Sorry but I think Robs turbos were the first and last upgraded twins I will ever build unless the masses just start pouring out crying for upgraded twins.
They cost almost twice as much as going with a good single setup and quite frankly they were a major PITA. If not for Rob's good graces and patience, I doubt the project would have ever been completed.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
OneJoeZee said:
I think it's a waste of time.
Don't be like me.
Take them off and leave them off. :)
Turbos need to be balanced. A rebuild kit is ok to an extent but once you rebuild them they need to be balance.
I agree with joe, but this might be a quick fixer upper for anyone on a budget. Although I believe it wont last long either.
MDCmotorsports
Indy 500
Wont last long = 10 seconds to 10,000 miles. It just depends on how bad they are out of balance....
The Doc
JZA70 twinpower
Aug 5, 2005
86
Netherlands
=> I surely hope not, 'course I'll be back if these baby twins live up to my expectations! :naughty:
=> Not to mention your effort and stamina, Jon!
