honestabe said:
From what I've heard and read, the stock twin's are only good up to about 350 rwhp. After that the turbine wheels crack from the heat. A good remedy for this is to upgrade to steel turbine wheels.
Adam
With a more open y-pipe, and bigger cams, you may find otherwise
There's a guy on SF running 370hp, and over 400ft/lb of torque on stock twins with what I rmember being not much more then a set of cams.
I will agree with you, heat kills these things. You want to get rid of heat, you get a more free flowing exhaust to dissapate, the heat, and larger cams, allowing the engine to consume the same amount of air at a lower pressure ratio, allowing the turbos to operate in a more efficient range.
