CT-26 SS oil drain line on SP61GT
aye mate
Hiatus over.
Maryland
All I needed was a flange and 45* fitting.
aye mate
Hiatus over.
Maryland
It should work, I might need to rotate the fitting to straighten it out some. The reason I did it this way because the drain that came with the kit didn't fit right. The pipe from the turbo hung lower than the hole in the block.
If you notice the first 2 pics its actually a smooth bend, the little pinch at the bottom was from something heavy being sat on it when it wasn't in use. It still flows ok though.
MK3Fury
Middletown, OH
Is it me, or does it look like that coupler is barely on the turbo? Might want to check that connection, wouldnt want that thing poppin off.
aye mate
Hiatus over.
Maryland
Yea its not clamped yet, if you noticed there aren't any nuts on the manifold studs either. I was just getting that oil line to fit right.
