i have a bic ddp and i was wondering if i got a t 3 t4 hybrid if i could still use the downpipe is the ct 26 a t3 exhaust housing
cjsupra90 said:NO, totally different flange and bolt patteren
Well actually you could, but you would need to buy one of the turbonetics turbine housings. They have a turbine housing that is basically a CT-26 housing that has been redesigned to use a T3 turbine wheel and a Garrett center bearing section.
MDCmotorsports said:And lots of machine work after you're done......
