Ct-26 cooling lines
supra90turbo
shaeff is FTMFW!
32
MA, 01440
go to an autoparts store and bring one of yours with you.
they should have a small reinforced coolant line like the factory ones. same ID, but it will be about 2' long with a quick 90* bend at the end. buy that. cut the 90 where you want it, and cut the straight one to length. you can even slip the little protective sleeve over the straight one so it doesnt wear through on the cps.
it's cheap and it works.
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
Better than the auto parts store, but more $, Check out JBL's braided set. I use them, they're awesome. Way, way , way! easier to put on than the stockers! :icon_razz Good stuff, worth the extra $!
My bad! :icon_redf It's the oil lines he sells... :icon_conf Sorry, and good luck.
