Crysis crashing during opening video... can someone help?
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
OK even I cant figure this shit out... heres the background of how it got to this point....
recently upgraded a few parts on my computer, I now have
AMD Athlon XP 3200+ Processor
*(NEW)*ATi Radeon HD 2400 512mb card (AGP, OC'd 590mhz core and 540mhz memory speed)
*(NEW)*3gbs PC3200 DDR ram
*(NEW)* Antec EarthWatts 650w power supply
I HAD vista running when I installed all of this, then so I thought hey maybe I can play Crysis now...
I installed it, it wasnt working for shit under DirectX 10, would not load. So I ran it under DX9c, it loaded but the sound was choppy in every part of the game, made it unplayable.
Then about 2 days ago I just said fuck it, put XP back on, a deeply modified version of XP to slim it down... needless to say, my computer fucking flies now.
So I run crysis, loads the menus, and all that PERFECTLY, no sound issues, no lag. I go to start a new game, and it plays the opening sequence all teh way up until the part where it shows INSIDE the airplane, you see the floor (where the camera starts) for a split second, and all the sudden, reboots the entire computer.
*I have throttled back my video card
*I checked cpu and gpu temps, they were fine
*I have tried a hacked DX10 for XP, as well as the DX9c it comes with, same issue
*I have tried a saved game file from the net, the second the opening sequence to THAT level opens where some guys are standing around, reboots.
Im out of ideas guys, I can't figure out with a FRESH install at that... why the fuck im having a problem.
4
-Make sure you have all drivers updated.
-Make sure Crysis is patched
-Make sure you have the newest redist of DX
Looks like the CPU is going to be your bottleneck on your system, so I'm unsure if it will run. I should try it on my box as I'm kinda close to your setup...
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
My cpu is the current bottleneck,
My drivers, to my knowledge are up to date, I cant get DX10 from M$ on XP for some reason? The website detects my setup and gives me 9c. Crysis is @ 1.1, Im getting it to 1.2.1 right now to see if that works.
Doward
4,245
Alachua, FL
This is an actual legit version of Crysis?
That said, knock your settings down to bare minimum, to ensure it's not a problem with the card/drivers.
Which Catalysts are you running?
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Settings are down to a BARE minimum. Right now my drivers are whichever ones came with that AGP Hotfix for my card, I dont know if its 8.9 or not.
EDIT: Catalyst version is 8.9
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Trying the ATi Hotfix for Crysis under XP, something about it fixing random graphic corruption during gameplay... well see
So far, 1.2.1 update does not work, DX9c Redist Aug 2008, nothin. Playing in windowed mode instead, nothing.
4
Might just not have the power to pull it off...
A couple games I've played I had to go into the config files and tweak the piss outta them to get the settings even lower. Also, you can set global driver settings for the video card to get things even lower.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Global driver settings? From where?
See I ran the game in Vista, it got past this point.. same setup.... so how could that be it? I just had choppy sound issues.
Heres my game log....
Stream Engine Initialization
Network initialization
[net] using Select socket io management
Physics initialization
MovieSystem initialization
Renderer initialization
Console initialization
Time initialization
Input initialization
Sound initialization
Sound - initializing AudioDevice now!
Sound - starting to initialize DirectSound output!
Sound - 1 drivers found:
Sound - available drivers: 0 Realtek AC97 Audio !
Sound - initializing FMOD-EX now!
Sound - initialized FMOD-EX
Sound - available record drivers: 0 Realtek AC97 Audio !
Sound - using FMOD version: 00040723 and internal 00040723!
Sound - initializing SoundSystem now!
Font initialization
AI initialization
Initializing Animation System
Initializing 3D Engine
Script System Initialization
Entity system initialization
Initializing AI System
[PlayerProfiles] Login of user 'Administrator' successful.
[PlayerProfiles] Found 1 profiles.
Profile 0 : 'default'
[GameProfiles]: Successfully activated profile 'default' for user 'Administrator'
$3r_FSAA = $60 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
$3r_FSAA_samples = $60 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
$3r_FSAA_quality = $60 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
[net 09:15:51.218] network hostname: computer
[net 09:15:51.250] ip:192.168.1.3
[net 09:16:49.953] connection requested to: <local>:64087
[net 09:16:49.953] resolved as: <local>:64087
[Error] <Flash> Error: CallMethod - 'gotoAndPlay' on invalid object. [Libs/UI/HUD_GrenadeDetect_Friendly.gfx]
[Error] <Flash> Error: CallMethod - 'gotoAndPlay' on invalid object. [Libs/UI/HUD_GrenadeDetect.gfx]
*LOADING: Level island loading time: 52.91 seconds
[Error] <Flash> Error: GFxLoader failed to open 'Libs/UI/FrontEnd/Mods.gfx' [Libs/UI/Menus_IngameMenu.gfx]
SupraMario
I think it was the google
The Farm
Make sure you have your CPU drivers installed. I know it sounds stupid, but AMD has some CPU drivers that are required for games, crysis is one of these games. Also Direct X 10 is only allowed on vista.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Installed newest AMD Drivers, still crashes.
swapped mem sticks around, still crashes
ran memtest, didnt find any errors.
Im almost at a complete loss unless its the version of windows Im running, I mean, it is modified like crazy, maybe if I did a fresh install of the standard XP... maybe... but thats alot of work to just TEST this.
Slight concern, My CPU is running at 55c right now, hardly any load.... stock heatsink and fan..... Im testing this under SpeedFan. Possible screw up here?
Also Im installing my Mobos newest drivers VIA 4.55, AGP and INF drivers, along with some other shit.
Doward
4,245
Alachua, FL
55c idle is way too high. Get rid of the stock heatsink, man!
Do a fresh install of a PROPER windowsXP setup, install the Hyperions, then the AMD CPU drivers, then DirectX then ATI's (amd lol) Catalysts (oh yeah, install .NET framework first, too)
Install Crysis
Report back
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
XP Media Center with SP3 sound good? Ive got that on hand or a a regular XP with Sp2 Integrated. I think the CPU drivers are pointless since Im not using a 64 bit processor, mine wasnt listed even tho it installed.
Also where the hell can I get a Heatsink today? Im out of ideas, I know best buy doesnt have shit, MAYBE radio shack, I might just go and look.
Kai
That Limey Bastard
Jesus - an XP? I'm surprised that it runs - the game engine somewhat expects SSE2, so i dont know if it'll even work without it. The minimum supported is a 2.8Ghz or higher - which means Athlon XP's just aren't upto the task. Athlon64 at minimum - and a Socket AM2 at that.
And your GPU is also barely able to play it - sure it ticks off all the features thats required, but it only has 40 shader processors.
To put it another way, i have two Radeon HD4850's with 800 shader processors each and i STILL don't break more than 28fps on average. Thats without AA or anything.
However, looking at your logfile, it looks as though it's initialising fine up to the point where it actually has to display the main menu, and falling down there because the files cannot be found.
Try a reinstall from scratch - and yes, make sure it's legit.
Oh and DX10 is a Vista only feature. No backwards hacks available.
Upgrade time, methinks.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Im upgrading soon but you didnt read the previous posts.
It RAN in Vista, whenI had it earlier this week, under DX9c, wouldnt even boot under DX10
My cpu is a 3200+ clocked at 2.2ghz techincally, but operates the output of a 3.2ghz speed.
I dont care if the game is in low settings, I just wanna try it out. Something odd is going on to make whats happening, happen.
Like I said, gets into the game, if I skip all the opening shit with spacebar, and it gets to where u see ur hands and ur skydiving, the guy on the radio starts to talk and wham, resets the PC. ANY part of the game I load, the second it has to render the people or anything directly related to INGAME, it fucks up.
drunk_medic
7Ms are for Cressidas
Woodstock, GA
I've seen this twice now. Do a google search; it takes about 10 seconds. People are working on DX10 for XP. Why? Because they hate Vista and want DX10. In the opinion of many people, the only reasons to upgrade to Vista are for DX10 and capability for more RAM, and many of them won't gimp their system for these features when XP runs fine at it's "limits". Just because it isn't an official release on the Microsoft website doesn't mean people aren't using it or it doesn't exist. That's like saying "Workstation 2008 doesn't exist. No forward hacks available".
That being said, the fact that it is an unsupported bastard-child mod of an official product for GAMING, and is working on a platform for which it was unintended from the get-go, would make me point fingers toward it when bad things started happening with games.
Normally I wouldn't recommend a fresh install, but if you deleted or modified the wrong files here and there when it comes to system files, you may have to invest a little time with a reinstall.
If you have things just how you like them and don't want to wipe that away, I would suggest disconnecting the hard drive and throwing another in there for your experiments. They are pretty cheap, and you don't need a high-capacity drive for an install of XP, drivers, essentials and a few games. Like I said, it will take a little time but if you have something else you can do while the installation takes place [and you intervene/guide it here and there when needed], it won't be so bad. Then you can disconnect the drive and put it away somewhere for experimenting later on; it can become your "control group".
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Maybe I should of mentioned, or I think I did.. I have a custom DX10 install for XP, had it on the first try, had the same results.
I have alot of hard drives.. alot... and this version of XP is pre modified, I didnt do it myself... Im gonna try with XP Media Center see what happens.
This is just bugging the shit outta me, if all else fails... Im booting up Soldier of Fortune II and causing all fucking hell online, havent done that in a long time.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Installed another version of XP, fresh, new
Updated EVERYTHING
Still crashes. Same places.
I orered a new heatsink for my CPU... Ill report back after I get it in tues or weds.
