Cruise Control question
Silent Smith
Jerk.
Nov 30, 2005
59
Mississauga
I put the correct turn signal stalk and wheel onto my car (89t, 89 wheel, 89 stalk) and now the cruise on light activates but the cruise cannot be set.
I'm going to go through the tsrm diagnostics tommorow but was wondering if having my abs throwing codes for both rear wheel speed sensors can cause this or if the cruise gets it speed signal independently.
figgie
Twin Cities, Minnesot-ah
GrimJack said:
There is only one rear wheel speed sensor - it's in the transmission. And yes, this will more than likely mess up your cruise.
rear wheel speed sensor is for abs not cruise :)
The cruise sensor is actually right on the speedometer gauge.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
BTW, the problem with my cruise was the switch on the brake - it was activating without depressing the brake, so the cruise wouldn't engage.
I adjusted the switches on the brake and clutch pedals, and it's flawless.
