Okay, so I did the "search" for a couple weeks... and observed the condition known as "blow turbo oil seals"... (rear seals... seeing as how the load on decel at vacuum would net the max white/bluish-tint smoke cloud...)
I believe mine were JUST starting to go... as it SAT for five years... totally idle. I think there were over 30k hard-charged 15lb miles on that thing.
Anyway... once I was convinced of the diagnosis...
I had to "think" about it a little... here I am "puzzling".
^^^ I start pulling stuff off... (spontaneously...)
...loosening band clamps...
...er... WAIT!!! Not the IC in the last two shots! We'll leave it on this round...
^^^ ...hmmmmmm... looking at my EGT probe... it is no WONDER the readings would jump erratically sometimes... (some "crusted" white shlit... perhaps going back to the BHG and later cracked head bleeding off toasted antifreeze...?)
I took some 400 grit to it and "polished" it down... (it works swell now!:biglaugh: )
^^^ OUT with the OLD!
...made it a point to inspect and clean THESE areas for the oil feed and drain.
^^^ There they are... BOTH CT-26 from TEC with "old school" T04b-type H3 trim spools... supposed to be rated around 380... my "G-tech" showed consistent 387/389/385 readings one day about 8 years ago when I first did some "poorly launched" pulls with it...
^^^ Pulling THIS one, which came LATER... but has around 30k+ hard miles of spooling on it... PLUS the cracked head issue for a couple years... notice the "crusted white" from the "cooked" antifreeze...:3d_frown:
^^^ EDIT! FUEL related discoloration... per IJ. below! (Thank you.)
-crisp
-crisp
