crankshaft pulley removal
bstevenson
62
Los Angeles, CA
hey guys, i need to get the crankshaft pulley off and have a puller, just dont have the right size bolts to use, anyone know what size/thread bolts i need to thread into the pulley?
steve_mk3
5
middletown, NJ
The crankshaft pulley is not on there that tight.
I used the bolt that holds the pully in place and a standard 2 jaw puller.
It poped right off.
Steve
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Mine took 3 days to pull.. with the bolt on type puller I pulled the threads from the pulley itself. I had to use the puller with the jaws.. not fun :(
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Sad.....but fotunately 9 outa 10 pulleys come off using a couple of large screwdrivers to get it started. I've done about 50 supras and 20R & 22R (Celica and trucks) motors that way.
I actually only had to use a puller once.:love:
bstevenson
62
Los Angeles, CA
yeah i used screwdrivers to pull the crankshaft pulley off of my old 240, but i figured since i actually have the puller laying around I may as well make use of it
SupraDread
153
New York
I used large screwdriver and shop towel. Put the rag over the screwdriver got under car and carefully tapped on pulley while rotating after every few taps. Worked like a charm no damage to pulley.
