Crank Sensor Location?
sao1
104
Santa Rosa, CA
Im looking over the wiring diagram on the Microtech LT12s for the 1JZ, and I have to wire the crank sensor and camshaft sensor. I think the camshaft sensors are on the intake side of the head, next to the valve cover. Correct me if im wrong.
But I do not know where the crank sensor is at on the engine.
Can someone help me out? The motor is from a MA70 supra, and it use a 2 row ecu harness. I hope that would help if it does.
Thank you!
Ken
350
Houston, TX
The crank position sensor on the 1JZ is right near the crank pulley, on the left if you are facing the engine.
