Hello, Bit of a problem. I'm doing all the timing case seals and the key that fits in the crank and lines up the damper is messed up I think. I Can put the key in the crank and it's loose then I put the damper on and it can move maybe 2 teeth (can only judge on timing gear behind it). Is this normal? The key itself looks like a slope with a ridge on one side and perfectly flat on the other side.
