Crambo's V12
Crambo
17
Victoria
Some of you guys may have seen this Mk2 build on other forums.
It's a long story and still a ways to the end, other info or pics just ask.
te72
Classifieds Moderator
6,610
7
WHYoming
1GZ-FE, right? Or am I mixing my letters and numbers up incorrectly? Either way, subscribed, I like how this is looking already...
Crambo
17
Victoria
The headers have equal length, 14" long primaries and approx 13" secondaries, so about 27" to the final collector in a small package.
The primaries are paired 180 degrees apart with a special merge to provide max scavenging.
URL=http://img571.imageshack.us/i/supragarage157.jpg/]
[/URL]
URL=http://img203.imageshack.us/i/supragarage199.jpg/]
[/URL]
Crambo
17
Victoria
To fit the 1GZfe there was:
Minor mod to the xmember to clear sump and fabricate all new mounts for V12 isolators.
Fire wall mods to clear heads, tunnel rebuilt to house T56.
Relocate park brake lever rearward about 4 1/2" because the shift is that far back from the standard position. (console will be extended to fit).
Mounts for sway bar lowered & forward for the bar to clear harmonic pulley and mounts also trenched to accomodate radiator (Ford with twin elec fans).
Top panel trimmed to allow radiator to fit forward for clearance also requiring the wiring loom to be relocated from between the radiator & condenser to behind the front bumper.
Yes, that is a Mk3 IRS, alot more work in fitting involved than the 1GZ!
URL=http://img31.imageshack.us/i/supragarage206.jpg/]
[/URL]
URL=http://img502.imageshack.us/i/supragarage050.jpg/]
[/URL]
Crambo
17
Victoria
Sorry for not providing engine details for those that have not known of the TOYOTA 1GZfe.
A Jap limmo motor, first built in 1997, afaik still in low volume production.
5 litre all alloy
Quad cam 48 valve
VVTi on intake cams
TVIS (now removed)
Twin ecu, twin drive by wire throttles
Built as a ultra smooth high torque unit to lug a luxobarge along side big Mercs & big Beemers.
Rev limited to 5750, nice torque from idle :)
400Nm about 1200 rpm
481Nm about 4500 rpm
