Cps replacement
ians13
537
Jacksonville, fl
i got a new cps to install is it possible to install this new cps and set it to were the old one was and not set the timing right away. i mean as soon as it get to work and get my hands on a timing light i will set it.
lagged
1991 1JZ
new rochelle
its been my experience that if you insert the CPS correctly 10 degrees will pretty much be with the bolt hole in the head lined up in the center of the flange on the CPS.
