I have a general question regarding the cps and the gears.
I removed the cps to take off the water housing. I did not mark the cps gears, will this result in the car not starting or running smoothly when I put it back on? I did not touch the cam gears or timing belt.
I am assuming since the cam gears and timing belt are lined up where its supposed to be, once I go to start the car, the cps gears will just catch into the grooves and all is ok. Am I right?
