CPS leaking?
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
hey, i just installed my cps i found out when i pulled it out, the o-ring was hard and brittle, so i decided to change the o-ring, after starting it up, it still smokes, could the cps itself leak?
nuggets
207
Boston
Its not uncommon for them to leak from the bearing/oil seal thats inside the unit. Then the oil pools inside and drips down through the cap and rubber gasket. If you take off the cap, are the internals oily?
BrandonW
1,300
N.J.
i bought that kit recently, stopped my leaking cps the only other piece i bought from toyota was the larger gasket that is between the cps and the cover
Intothenight19
Crissaegrim
Feb 23, 2006
221
Pa
Years back when I bought my car I had a phantom oil leak and it was none other than the CPS, do as the others say above and buy a rebuild kit. Quick and easy..Best of luck to you!
