CPS Connector angle = no start?
MA70witBoost
Registered Drifter
Ok, I've noticed this much about my motor... At times, the car will start perfect... other times, it turns over but no start, you have to play with the connector for the cps... not the cps its self, but you know how the cps's plug has a screw for adjustment? well the angle of that is like a form of tuning too! or atleast it seems that way... any one know if this is valid? Or if there is something else up there... Im trying to fix all the little problems mines has... Just trying to get some assistance diagnosing. thanx again
8,894
There is no "adjustment" on an electrical connector. The bad connection is probably you reason for an intermitent no start.
Have a pic of the screw you are talking about?
lagged
1991 1JZ
new rochelle
if by "adjustment" you mean bad wiring and "form of tuning" you mean that youve got to solder the bad connections then, yes, youd be right.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
mabye it is the srew that holds down the connector brace on the cps
NashMan
Aug 5, 2005
4,940
17
Victoria BC
MA70witBoost said:
yeah, it is... i mess with that and some times start, and others no start... and its proven itself to me several times... on multiple occasions ive been able to resolve a crank/no start issue in this manner... any ideas?
you have bad soder joint in you cps then repalce cps
Ish
SM Pimp
Socal
It might also be the wiring harness wires for the CPS. I had that problem, had to cut them and solder them on right.
MA70witBoost
Registered Drifter
Wiring harness is brand new... Cost me $540, the cps is the second one i have... The one that came on the car was worse... bought this CPS used off of www.suprawarehouse.com, they said it was in running order when they took it off the supra. id have to get a multi meter and test the cps... i take it that i shouldn't be having any problems starting my car just becaues of the angle of the connector brace?
