Coverting a n/a to turbo?
MX1
11
Wisconsin
I have a n/a body an chassis supra with a 7mge in it.The guy who had it before me put a ct26 stock turbo system on it:cry: .The motor is knocking and I plan on making it a complete turbo motor.I have a 7mgte block for it already.What can I use off the n/a without any complication or fabricating.I would like to use the head if possible.The n/a motor already has a cometic mhg in it and arp head studs.I plan on getting new rods,pistons,rings,an oil pump,timing belt kit,rod bearings,main caps,arp rod and main bolts.I've also noticed that n/a have distributors and a coil igniter.Will this be a problem since I think that 7mgte have coil packs?I have many more ?'s but these are a few for now.And one more thing.Will the tranny bolt on and how much hp can it hold?:1zhelp:
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
N/A and turbo heads are the same but one cam.
the rods, crank are the same, the pistons arent.
uhm,
You'll need a turbo igniter, and Coil pack.
and alot more stuff if your 100% converting to na-t or just gonna use n/a electronics.
