im in the process of putting a JDM 7m-gte from what i believe is a 90-92 into my 87 turbo supra. since the wiring harness was for a left had drive car and a later model supra i had to switch over my old wiring harness(which sucks cause the one that came with my engine was flawless). so i switch over my old one and my old thermo housing(cause the sensors are different)
is there any other parts in going to have to switch over that are different?
is the supra wiring harness able to be soldered? is it not tin wire?
will my old egr just screw into my new engine(which has no egr)
is there a part number on a throttle cable that will work for the jdm throtle body? im just using my old linkage and throttle body for now but i would like to eventually use the other one, just looks cleaner and is more simple.
also, that pipe that hooks up to the lower heater hose, well since the one with the engine is for a RHD, the hole is on the wrong side. i didnt notice till the engine was in and i dont wanna have to pull it out again, will it hurt anything to just run heater hose all the way to the other side?
TIA
TIA
