Could it be a relay
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
All right a friend of mines MKIII windows arent working his interior lights powerlocks and radio doesnt work is there either does anybody now what it could be and the location of it?
bluemax
The Family Man
Orange County, CA
It sounds line a connector somewhere is loose or off or a common fuse.
Check the wiring diagram and trace it to see where all of these systems share the same connector or junction box.....
OK, I checked the TSRM wiring diagram and those systems are on the same line.
http://www.cygnusx1.net/supra/library/TSRM/d/D_15.html
If I am reading this thing right, it could be the Pwr CB #14
http://www.cygnusx1.net/supra/library/TSRM/be/BE_013.html
Located in relay block #5 on the drivers side kick panel.
http://www.cygnusx1.net/supra/library/TSRM/be/BE_010.html
bluemax
The Family Man
Orange County, CA
If you have an ohm meter, check the power at the CB receptacle in the relay block to see that it has power with the ignition on. If it does, then its probably the CB. If not, then you might have a bad connection upstream or at the relay block.
