cosworth guy to see supras
Sideways_bob
62
KY
I am josh. I am a big fan of cosworth escorts and have built a few here and there and found a car with pop up headlights here in kentucky and now i am in love with supra.
here is the car i dont know if i can get the pictures to work correctly
its a 5 speed non turbo 87. i want to keep it stock and get everything to work and drive it normally. just done a headgasket and it runs fine just have a vaccuume leak. has 277k miles on it and i plan to get it to 400k
here is a photo of the engine. has electrical rad fan and weird looking valve paint colours.
Sideways_bob
62
KY
RockPaperSwoRD;1362260 said:
are are you using it as a daily driver, or planning a swap?
Not going to swap i want to drive it daily as now it has a thermostat leak
the threads in the water neck [what hold the therostat] has stripped threads which caused a water leak, which caused it to get hot and blow the head gasket
now that i got the headgasket fixed i am trying to get it to stop leaking so i can drive it daily
I want to leave it non turbo and get it to run smooth as margarine before i take it to the road. only plans are to restore the car to factory condition.
thanks
Supracentral
10
thanks
You can remove the water neck and tap & helicoil it, or replace it. Only 2 nuts and 1 bolt hold it on.
There are probably a few for sale in the classifieds, or you can post a WTB ad in the appropriate section.
Sideways_bob
62
KY
That is a good idea i hadnt thought of it like that now i get to use my tap and die set weee :biglaugh:
