Cost to install a Metal HG
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
If I was to pay a shop to do a metal HG for me what do you think it would cost? I dont need one now, but the prev owner had a Felpro gasket and ARP studs installed, I dont know why he did not do a metal one but now that I am about to hit about 400hp I am thinking it may be a good idea?
what do you guys think? and a rough cost?
thanks!
LordLo
242
OR
thanks!
Last I heard the stock hg could hold up to 400 hp... as to how long it'll hold... :aigo:
jdub
Feb 10, 2006
10,730
Valley of the Sun
HP is not what you should be looking at...boost level is your concern...related, but not the same. Boost effectively increases your compression inside the cylinders putting stress on the HG. 12 psi with a good tune is a pretty safe bet on a composite HG...14 psi is starting to push it.
You also need to be thinking fuel when running above 12 psi. If you lean out, causing detonation in one or more cylinders even a MHG might not save you.
A lot of the cost for a MHG is the reqired RA (smoothness) spec for a MHG. 30-50 RA is the norm depending on the MHG you use. Both the block and head have to be decked to this spec...this increases the cost significantly. That's why a lot of people stay with the composite HG...it does not require the level of smoothness a MHG does. You don't have to pull the motor, only the head.
Edit: Just looked at your Car Domain site...I see you are/have upgraded your fuel system. Good for you man. Now get a wideband so you can see what it's doing ;)
Boosthpy
133
Idaho Falls
Hm no big hp plans here yet. Composite sounds good to me. So just Toyota composite and head studs will be good to 12psi on good tune?
MRSUPRA
838
Maryland
I would not bother changing the headgasket if its not blown. ITs too much work, or too much money. With ARP studs, the felpro might hold up longer than you think.
drbowser3
The Doc is in...
Jan 17, 2006
215
Tampa,FL
Call up Fernando @ F&H Performance (813-631-9500), I think labor would be $500. Then you would need the gasket and machine work. They can get the gasket for you, plus a machine shop is about a mile away with quick turn-around.
