Hello, I'm lost on my car. I have a 89t and the gauge has always read at max hot, it can run for like 1-2 mins slowly climb then around halfway it just skyrockets. I was having huge problems with bleeding the cooling system and then hoses started blowing. #6 developed an audible miss and the drive ability went way down so I figured it was just time to do the HG and stop denying it. I pulled the head and the gasket looked good. #6 piston looks alot cleaner then the others (coolant steam cleaning the carbon?) I have no idea what to do now. I'm planning on getting a toyota oem headgasket and using arp bolts but the head shows no visible cracks, I have'nt checked to see if it's warped or not. Theres no real traces of a existin coolant leak anywhere on hte motor, the heater core return line started to leak as of late but I figured that was just the lines blowing from BHG
I replaced the tstat, no differnce
Fan is not a issue as it's f@##ing cold around here and theres no diff
Rad cap, not sure - going to replace it
water pump looks new,
What should I do guys, I'm running outta time and money trying to fix this. Can a bad water pump do this, something I'm overlooking? The car ran fine for 5k and there was no differnce so I assumed the gauge was FUBAR.
