cooling system pressure.
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
my car isnt overheating..
but i have large amounts of pressure in the cooling system.. my hose from the pump to the radiator is incredibly bloated. when i squeeze it, it feels intensely pressurized. the radiator is warm, but not hot, same with the pump.
i had previous cooling issues when i lived in 110 degree weather, but since then i moved to the coast where its a constant 50-65 degrees, and the car doesnt overheat here.
any ideas?
Nomad707
Im From The Bay
Mar 14, 2007
1,039
its not a BHG i promise. I just did a HG job 2k ago with a 2mm metal gasket, arp studs torqued to 85..
its running awesome though.. no signs of bhg... no overflow tank activity, no bubbling sounds.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
that happened when i needed to replace the hose it was getting old and bloated... should be the same for every coolant hose in your car
suprahilux
ULTRA Lurker
Jun 12, 2007
125
conroe, texas
I rebuilt my 7m and about 2000mi into it, the coolant system was running at unusually high pressures. I kept trying things left and right while denying that it was the head gasket. But it didn't quit until I replaced the HG.
Not saying that's it, but don't shut out the possibility.
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
Replace the radiator cap. 12.7 PSI or .9 Bar.
And dont get one of those shitty ones with the pressure release tab, they tend to fail alot.
It might also be a good idea to check your thermostat, maybe its not opening as it should.
PROJECT N00b
XBL: Mkiii DriFt3r
May 22, 2005
1,660
honolulu, california
Ah shit...I just bought one of those CST rad caps with a pressure release feature. It's still rated at 13 PSI though.
