Cooleeze Intercooler Hard Pipes
89Turbo
804
Portland
heres what it says on his ebay thread:
This is a full intercooler pipe set that replaces the ageing restrictive stock plastic/rubber hoses. The larger diameter and smooth mandrel bends allow more airflow and are designed with much less restriction which will equal more horsepower. The IC and turbo ends are 2.25" allowing stock hook up.
i was told the stock IC is 2"in and 2"out so are these still going to work?
mkIIIman089
Ohio
I use em... work fine but the initial install is pretty rough unless your a body builder. The couplers are VERY VERY tight on the lips he puts on; which makes it great for not blowing couplers off, but hard to install.
mullenc525
33
The stock IC is 2.0". If he supplies reducers, then it is perfect. Otherwise, he may supply 2.25" couplers, which will crush down OK but its not ideal.
At least I know 2.25" couplers will crush down to 2.1" without kinking or leaking.
