coolant temp gauge doesnt want to work =[
drod23
60
Santa Paula, California
the coolant temp gauge on my dash stopped working....
i noticed the wire broke inside the connector, and the coolant temp sensor sender no longer was good
so, i replaced the sensor with a new one from toyota and replaced the connector with a spade connector and soldered it together, but still doesnt want to read on my dash
can anyone help with this problem dont know wat to do from here???
James T
22
Adelaide
Hi drod 23
do you have the electronic gauge?
I had a similar issue with my 89 GT. you need to make sure the sender unit puts out the right resistance.
drop he sender into some hot water and measure the change.
