had problems with car overheating, so i:
-resurfaced block
-resurfaced head
-arp studs
-1,2mm hks mhg
so i started it today and it was running fine for about 10 min and then started pushing coolant out again!!:aigo:
the only thing that i am thinking that it could have been is that when i put sealant on the area where the block meets the front timing cover plate i put the heat on and didnt torque it down till the next day, do you guys think this would be a problem? what should i do now? im thinking take the head off and scrape off the old sealant, put new sealant on and torque the heat down immediatly, possibly spray on copper spray on the hg? i would really appreciate any help, thanks
-resurfaced block
-resurfaced head
-arp studs
-1,2mm hks mhg
