coolant problem....
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
okie so my turbo supra is leaking coolant.....when its not even be driven....its not my daily driver... its beensitting for about 4-5 days.... and i see a pretty big leak of coolant on the ground....its dripping right in the middle of the car.....i dont think its my radiator...so it has to be one of my hoses right?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Check your heater hoses. There's one on top rear that goes to the heater valve and another on the drivers side (return line) that goes to the big metal line around the block.
There's also a short line that runs from the back of the head down to the metal block line on the rear passenger side...real pain to see & get to.
I'd consider replacing all of the above...if any one of these let go, all of your coolant will be on the ground very quickly. If you're on the highway, the car will overheat almost instantly...this happened to me...it destroyed my head gasket.
