coolant pressure tested
sketchy_89
20
adelaide
hmmm did a coolant pressure test...left it on for half an hour....pressure went down but couldnt find ne leaks....put radiator cap back on n started it fine...but then it was idling rough until i gave it a rev n then it came good...water got into cylinders?
8,897
ne isn't a word.
How much pressure did you apply, and how far did it drop. Pressure can't hold forever. Afterall, the radiator is designed with a controlled leak. It should hold fairly steady. With a leak that is obvious, the pressure tester will drop pressure quickly. Like right now. Check the cap itself, if your tester is capable.
sketchy_89
20
adelaide
i went to 15psi and it went down to about 10 psi....it was running rough tho wen i started it and it never runs rough...and its a new radiator cap n thermostat
