coolant light
ma70mkiii
139
ohio
Ok my coolant light is being stupid. My radiator is full and there are no leaks but it stays on and it flashes from time to time. It used to come on when the car was cold but once it come up to operating temp. it shut off. It wont go away. plz sumone help.
Tgood
All throttle no bottle
Dec 16, 2005
206
ennis/dfw
Check your overflow tank. I'm not positive but I'm pretty sure the sensor is in you overflow.
Taylor
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
SupaMan said:
the sensor is in the overflow tank fill it up.
x2.
If you make a hard turn even with the coolant overflow mostly to the full line, you can make the fluid move enough to drop the sensor low enough to trigger the light.
If its on while you're simply driving along, you're fluid is low inthe overflow, or you have a bad sensor.
88YotaTurbo
658
Wolcott, Ct.
mine has been like that for a year know. fill you reservoir tank and check for small leaks. Mine had a small coolant leak coming from the lower rad hose. I replaced the clamp and filled everything up with coolant and purged the system of air. good to go now for almost 6 months no more light. :)
