Coolant light issue
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Coolant light indicates that you have a low coolant level in the overflow tank. Make sure it is full, and if it is, then you have a problem with the sensor at the bottom of the bottle or a wiring issue, more than likely a stuck float on the sensor.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Yeah mine is always on cause the float doesn't float. Take a look to see if is actually floating, if you can't see take it out so you can see better.
synystermk3
North Carolina
Well yesterday I emptied the coolant overflow tank and and checked the plug on the bottom had come loose so now the coolant light issue is solved thanks for the advices everyone
