I spent the better part of a day taking the intake manifold off cleaning it and then replacing TB coolant feed line and TB to ISC line. The leak is back <insert minimum 3 dirty words>.
http://www.cygnusx1.net/supra/library/EPC/MKIII_NATO/291420/1603_2.html) shows the Tb feed line #16267 and on the same hard pipe there is what looks to be a cap off #90339-16001. I did not see the cap off, I thought that was the heater core line.
little backround on my car. When I purchased the car the coolant gauge was stuck on high, the mechanic that sold it to me (old co worker) told me it was just the sensor so I replaced it. Now it starts cold then skylines. I've done a coolant flush, new Thermostat, few new hoses and the gauge will start low then rise somewhat normally until about mid point where it sits then skyrockets again. I have heat and the odd time I can hear a coolant rush but it's cause I cannot get the air out of the system. It drives fine, no idea on what do if the leak dos'nt fix the problem. The head gaskets recent aswell. There is a large crack in the turbo housing, starts at the waste gate and reaches towards the turbine. Thought I saw somewhere that this can let coolant escape and make it over heat
Any advice would be helpful, I'm tired of cleaning the driveway.
