Coolant leaking inside my car
mattgo
211
Anacortes, WA
I finally found where my coolant was going. I took my carpet mat out to clean some dirt and I noticed a small puddle of coolant soaking up my carpet on my front driver's side. My dad said the heater core is cracked or something. What do you guys think? How hard is it to replace the heater core?
thanks
JesseH
1,153
Englewood, Ohio, United States
thanks
yep, deff. the heater core.... just to give you an idea of how much you have to take out I attached some of the pics when I did mine. I know it looks like a lot, but if you just take your time and when you take bolts, nuts etc off put them in seperate baggies so you know where they came from its not that hard
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
Don't assume anything... After pulling my engine for my 5 speed swap, I had a slow leak on the driver's side. It turned out to be a loose hose clamp on the engine side of the firewall that was somehow causing a leak into the cabin - not the heater core. Weird, but true and definitely worth checking out before diving into a heater core swap. Here's the thread I started at the time:
http://www.supramania.com/forums/showthread.php?t=33829
Oct 11, 2005
3,816
Thousand Oaks, CA
Before you start, make sure it is not just leaking at the hose outlet on the firewall. Coolant can run down from that connection into the dash. I would hate to take the dash out to find it is just the hose connection.
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
If you've never done it before, start early on Fri. night and hopefully you'll be done Sunday about 4 or 5 am. At least thats how long it took me. Or get buddy to come over and do it, since he figures 5 hrs. Christ, it takes 5 hrs just to crawl over the piles of crap in there.
mattgo
211
Anacortes, WA
me and my dad will be working on it, We're starting after church on Sunday. We still got to fix the transmission on my truck first.
