coolant leak
EvoLuTioN
no-JZ Your Mom!
Mar 10, 2006
508
Bed
what would cause me to be losing coolant over time? I don't visually see any leaks, and my heater doesnt blow hot air. Besides that, I would have to fill up a small amount of coolant after a drive, or if I boost, then I can see my oil pressure start to drop a little more (due to coolant lost), my temperature would start to move up, and my overflow would be filled up completely. Once again, visually I don't see any leaks, not from the waterneck area, lower radiator hose, nor around the back by the firewall. Help?
Supratrbox2
Damnit
Jul 27, 2005
133
South Jerzey
For a little while I had a slow drip that was coming from the petcock drain that would leak over time but then one day just stopped. Check that out too.
macjac69
274
Mississippi
Reach down at the bottom of the radiator and run your finger across the drain plug that's where mine was seeping.
