Coolant in spark plug valley :(
mytmk3
643
christchurch
Looking for ideas here realy hope it's not a worst case thing here
There's no coolant splatter under the hood so there's no where else from it to come from other than the head between 3-4 cylinders
Here's the photo
Motor was rebuilt done 8+ hours dyno time and maybe 500kms on the road
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
the large hex plug in the bottom of the spark plug valley seals the coolant passages. the only thing I can think of is that it's leaking, and those should not have been touched when the motor was rebuilt
mytmk3
643
christchurch
That looks like fun :( is the world going to implode if I ignore it for a little bit to make the drags this weekend? It doesn't exatly leak in a hurry
CT26smoker
223
Houston
mytmk3;1698885 said:
... is the world going to implode if I ignore it for a little bit to make the drags this weekend?
I wouldn't.
Leaks can always get worse.
It's an hour job, maybe 2 to make up a custom tool to break them loose.
Drain your system, pull the plugs, clean and reseal them.
Job done.
An over heated 7M tkes a bunch more to fix.
---------- Post added at 11:08 AM ---------- Previous post was at 11:06 AM ----------
jessemkiiis;1699061 said:
I made my own tool to remove these, found a bolt the fit and welded a nut to it.
Yup, did the same here.
You could also find some hex stock, or a long nut that you could then put a socket on.
