I was wondering if you can not run coolant through the Idle Speed Control unit like you can with Throttlebody without problems?
Thanks
Thanks
Strannik said:yeah you can
what i did on my car is put a small metal ball into the coolant hose where it enters the ISC to effectively block off both ISC and TB ( i was too lazy to disconnect hoses )
rumptis said:it won't affect the Idle speed though?
malloynx said:the coolant in the isc and tb have nothing to do with the performance of the units. there there to prevent freezing up and to reduce carbon build up.
