So im in the process of designing and building itbs for my 7mge. I would like to not use the stock afm and go speed density system instead. Those of you already running speed density would you mind suggesting a piggyback system to use? also can you explain to me exactly how it reads air density. i understand a temp sensor needs to be tapped in the intake manifold. in the case of itbs would i need to tap one for each intake port?
thanks for the help
Anthony
thanks for the help
Anthony
