Hey guys, for the past month or so my car has been a pain in the neck. It stalls from point A to point B more than any car should. Did I mention it was auto? Anyways, regardless if i'm going 10 mph or 30 mph, coming to a stop or just slowing down at a higher speed, my rpm's drop to 200-300 rpm, sometimes picking the revs back up or sometimes stalling. This happens when i completely let go of the gas pedal, to avoid stalling i have to ease it down slowly. I am downshifting my auto more than any of you standard guys just so my car doesnt stall out. I'm getting a code 51 when I do my code checks. There is a split second hesitation when you pull on the throttle to rev the engine, my idle in park is at a smooth 650. I do not believe its a boost leak, im running at 8.5 psi with a shimmed wastegate, K&N intake, HKS bov and 3 inch exhaust. My problem with this started before I modded anything on my car.
We had the canada mini-meet out in Surrey yesterday and the guys looked at it for a bit, but no dice. They suggested posting it for more input. The day it started happening was the day i removed my charcoal. Thats the only thing i touched that day, however that shouldnt do shit as far as i'm concerned. I put it back on and it still runs the same shitty way. Yes, it is on correctly. Need some help guys :icon_bigg
