Hey all. Last Hurdle before everything is running Properly.
First, When I start the car up in the Morning, My Wideband A/F readings are 14.8 to 15.2 or so and when Im driving it for the first time at normal cruising range its sits between 14.5 to 15.5 or so..
Now here is my Dilema... Once I turn the car off and walk into a Store or whatnot, Come back outside and start the car up, The wideband readings at Idle Drop down to 12.3 or so and under normal Acceloration its sitting around 12.5 and sometimes it even Drops down to around 11.4 or so. I end up having to Lean it out on my SAFC to like -18 and -21 and that only brings it back up to around 13.6 or so. I dont like to Adjust it that much as Im not for sure what the Actual A/F levels are since everything is going Crazy. And Ofcourse No boosting at this Point at all.
Next Morning, I end up having to reset everything back to the Original settings that I had them at before.
Does this sound like a Wideband sensor going out. Im using the AEM Uego Wideband. I did get a Check Engine light one time and it came up as O2 sensor Deteration but I changed the Narrow band O2 sensor about 2 weeks ago and still no change.
Sorry for all the Questions, You all are my Heros :icon_bigg
Robert
Robert
