hey guys this weekend i'm pulling apart my engine bay so that i can clean it up a bit and i figure i would tackle this code 52 problem. I think the problem is a loose connection somewhere, so far this problem has happened with the orig wiring and the new rewire i did, usually what happens is everything will be fine for a couple of days then i have to connect and reconnect the connector, so i'm thinking makybe the connection from the knock sensor and clip is bad. Am i supposed to be putting some kind of electronic grease there?
