Confused about cam angle sensor and limp mode.
kuwugata
28
Hollywood,FL
My car was running in limp mode. I was going through everything checking what was working. Crank sensor was good. I took the first cam sensor off and it ran worse so i put it back on and went to check the rear cam sensor. When i removed it the car was out of limp mode and revving fine. besides an inconsistant idle and breaking up in boost, its runny better. Anyone have any idea whats going on?
mk3tattoos
1,104
Bremerton, Wa
See if your caps are leaking, if the are it can be fixxed.
Do you think that was related to the problem when it would bog when you gave it gas?
