As of lately, like maybe today, I noticed the ac condensor fans are not coming on with the ac. Checked all the temp switches on the thermostat housing and all are plugged in.
Any thoughts?
Wayne
Any thoughts?
Wayne
Nick M said:Do what he said first. There is a dual pressure switch that should close electrically when the fan needs to come on. If it is defective, a new one is the only fix. Aside from fabrication.
johnathan1 said:my "fan" (note: I have ONE) Is this normal? Am i supposed to have two? Seems to turn on and off peridocally while driving, like it won't be on, then I stop at a drive thru, and I hear it kick on, then about a minute or two later, it turns off...is this normal??
3rdtimearound said:Acccording to the TRSM--- the dual pressure switch--1 and 2 should be open less than 30 psi or above 384 psi.
Before I got this post, I got my TRSM and made sure the fans are indeed working by going to each relay and "jumping" across it to emulate the relay indeed doing what it is supposed to do. They all were working properly.
So I went further upstream to the dual pressure switch---unplugged it and checked for an open, it was open but the engine was off with the key on and a/c on.
So again further up the circuit I went---jumped this switch and wouldn't you know the fans kicked on. In the morning I will jump this swich again and see if the fans come on with the motor running and a/c on.
Thanks
Wayne
Me said:There is a dual pressure switch that should close electrically when the fan needs to come on.
mrnickleye said:'89 N/A. no fan out in front of radiator. 2 little electric that only work when a/c 'high side' pressure gets up to a certain point. Usually not on when cruising at hwy speeds, as enough air passing by cools the condensor.
On the passenger side of engine compartment, along the frame, out from the oil filter, are 2 sensors in the small 'high side' line.
One (closest to firewall) is normally open, then closes when pressure comes up, to complete the fan circuit, thus allowing the fans relays to operate the fans. . If this switch goes bad, you can put a jumper in the connector to by-pass it. The fans will always be on when the a/c is on. Better that than not on.
The other one (closest to radiator) is a 'high pressure safety' switch. It is normally closed. It will cut the power to the compressor if the line pressure goes too high. This is to help save the compressor. It operates (opens) at approx. 325 psi.
Those little fans pull a LOT of air. I put a switch in the dash, in place of one of the coin holders, to turn them on when I want. The switch grounds the 2 relays.:biglaugh:
