alright i just recently picked up a T'netics 60-1 with a custom cast exhaust housing to bolt onto the stock mani.
After the install my BOV doesn't work (vac lines and everything are fine believe me) but the turbo has a 2.5 in. outlet and im on stock IC pipes (yes i know i need to upgrade them but i can only do a little at a time) right now i have the porsche bosch BOV and then i tried the higher grade bosch porsche BOV, and neither one of them work......
i can be in 5 in. vac. and the bitch will surge like a mo fugga. so out of 2 BOV's both will surge.
so Tissimo (on SF) and i narrowed it down to either the BOV isn't big enough for the air flow/volume, or the IC pipes are just restrictive and causing it to surge.
What are your thoughts on this guys????
thanks for the help in advance.
