compression test
SupraTrbo89
234
7
West Chester, PA
I was just looking at what I need to remove for the test...it seems like I need to remove the throttle cable mount as it is blocking plug # 5....how do I hold the throttle open with this removed?
hvyman;1969082 said:
Yes so the car doesn't dump fuel.
Also hold the throttle open wide open.
With you hand and have someone else crank it.
Or put the tester adapter in the hole and then temporerly put throttle linkage on.
